Displays ARP validation information for the specified VLAN.
| vlan_name | Specifies the name of the VLAN. |
| vlan_list | Specifies a VLAN list of IDs. |
N/A.
The following sample output displays ARP validation on for the VLAN valid:
# show ip-security arp validation vlan valid ---------------------------------------------------------------- Port Validation Violation-action ---------------------------------------------------------------- 7 DHCP drop-packet, block-port for 120 seconds, snmp-trap 23 DHCP drop-packet, block-port for 120 seconds, snmp-trap
The following example shows ARP validation if configured through RADIUS:
# show ip-security arp validation "Default" ARP Validation enabled via RADIUS ---------------------------------------------------------------- Port Validation Violation-action ---------------------------------------------------------------- 1 DHCP drop-packet 2 DHCP drop-packet 30 DHCP drop-packet
This command was first available in ExtremeXOS 11.6.
The vlan_list variable was added in ExtremeXOS 16.1.
